ELD - What does it do?
Old Feb 1, 2005 | 08:30 PM
Dave Slater's Avatar
Default ELD - What does it do?
Accord 2004 ex.
I want to make the accessory power outlets hot all the time so my GPS and Computer inverter stay running while I shut the car down to gas up.
One way would be to jumper the accessory control relay contacts, but that would leave the current draw running through the ELD. I believe the ECM is watching the ELD and would see that unexpected current. Would that be a problem?
My archive searches reveal that the ELD is sensed to verify electrical load and raise engine idle rpm to suport electrical loads if necessary. Apparently if too much equipment is added the ELD sees a current draw level higher than some factory limit and kicks a 20 code. What else is it doing?
Thanks for your help.
Old Feb 2, 2005 | 09:04 AM
EE_Chris's Avatar
Default Re: ELD - What does it do? (Dave Slater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave Slater &raquo;</TD></TR><TR><TD CLASS="quote">Would that be a problem?</TD></TR></TABLE>
It really shouldn't be. Worse come to worse, since it seems you're competent to wire things, you can always hardwire the outlets to the battery thus bypassing the ELD altogether.
Hondas run so lean at idle that an electrical current demand of a decent size will make the idle bobble a bit - so the ECU uses this to counteract that.
jdmland
Apr 9, 2008 01:38 PM
philkehn
Jul 11, 2006 05:02 PM
smithdsmith11
May 6, 2006 06:00 AM
SOHC-Tech
Nov 26, 2005 12:24 AM
NovaKnowledgeNow
Apr 16, 2005 03:43 AM
