Can i swap a OBDII (96+) LS Throttle body into my OBDI LS (94-95)
I have a 1995 LS. The OBDI Throttle body is the style that has the Fast Idle Thermo Valve on the bottom. Would I have any problem swaping in a 96+ OBDII throttle body .... the style that doesnt have the Fast Idle Thermo Valve attached to the bottom.... just hook up the lines to the 2 nippz .. (So i would no longer have a Fast IDle Thermo Valve) .. and can i also use my OBDI Map sensor off the 95TB and put it on the 96+TB
Re: Can i swap a OBDII (zilverz)
For as much I hate to be a jerk .... I cannot .....
So I'll be fair.....
Yes you can use it w/o any problems. I've done it both ways and no codes. No need to change your MAP sensor either the OBD-2 will work off the same TB.
Re: Can i swap a OBDII (Honda4CX-R)
Well the shipper didnt include the map sensor with it when he sold it to me .. .so i have to use the one off my 95... but cool .... i had it all apart last weekend and was reluctant to try it ... but i will this weekend thanks honda4!
