h22 question
Re: h22 question (khoalie)
yes the h22 has balance shafts. they are located about half way down the block, one in the front, one in the back. an auto trans. flywheel is called a flexplate.
Re: h22 question (h22 civ)
thanks for the reply
anyone have pictures of these balance shafts on a stripped block?
so i guess the f22 and h23 have balance shafts too
so if you get forged internals and get your crank balanced and knifedged,
would you also have to get your balance shafts balanced as well?
TIA
TIA
Re: h22 question (hondaZvic)
Take those puppies out. Itll free up like at least 10 whp... Might vibrate a little more at idle. Im prolly gonna take mine out when i do my timing belt, water pump and cam and valvetrain.
Re: h22 question (EK22Tim)
yes Shop up in lexighton ky does it all the time and see gains anywhere from 7 to 12whp. Pretty nice ah. You could always put it back on if you dont like the way it feels.
Re: h22 question (jDmDxTuRd)
Just disconnect the balance shaft belt. DON'T REMOVE THE SHAFTS AS THEY ARE TIED INTO THE OILING SYSTEM.
[Modified by 2point6, 10:07 AM 12/23/2002]
Recklessnenito
Engine Machining & Assembly
06-04-2018 08:41 PM
