Del Sol B16A
Old Dec 22, 2002 | 06:52 PM
alexbyoung's Avatar
Default Del Sol B16A
What would I need to put a B16A into a del sol with a sohc non vtec and about how much would it cost. Thanks for any help.
Old Dec 23, 2002 | 12:09 AM
bb2vtec's Avatar
Default Re: Del Sol B16A (alexbyoung)
You will need the delsol DOHC linkage because its the only one that fits.It is like 4 inches longer than integra and Si. The rear mount bracket because its longer too. The P54 delsol dohc A.C bracket because its the one for your A.C compressor if your going to keep it or B20 compressor bracket.You also need the front transmission bracket too. The timing belt bracket you use the same unless you have the integra aluminum mount in that case just use the integras timing belt side bracket then tranfer the sohc mount to the top of the tranny. axles are just 99-00si,delsoldohc or any94-00 integra but they all must be manual tranmission axles.The ecu is just any obd1 dohc vtec or if you have obd2 then 96-98 dohc vtec. throttle linkage just use delson dohc.
Old Dec 25, 2002 | 01:28 PM
pennies_hatchie's Avatar
Default Re: Del Sol B16A (bb2vtec)
search
bboyjimpy
15
Jan 18, 2010 07:44 PM
roc
Feb 29, 2004 06:01 AM
totaled
Sep 11, 2003 02:00 PM
Soled Out
Dec 21, 2002 05:12 AM
