91 civic std. (4 speed)
Old 12-20-2002, 06:06 AM
R@mon's Avatar
Default 91 civic std. (4 speed)
im currently helping a freind swap a b16 into his 91 civic but upon searching through http://www.hasport.com i found that they recomend that i swap the knuckle from any other 5 speed civic or crx over to my freind civic. i really dont know why but maybe someone could help...
i really want to know if this is completely neccesary to work the b16 into this chasis?
http://www.hasport.com/Tech/Installs...0partslist.htm
[Modified by 93h22a4, 7:14 AM 12/20/2002]
Old 12-20-2002, 07:19 AM
omahaturbocivic's Avatar
Default Re: 91 civic std. (93h22a4)
The hubs in the civic standards and hf's are smaller than any other civics and the b16 axels will not fit because they have too many splines. You need to get a set of knuckles off of a 88-91 civic or crx dx or si.
[Modified by omahaturbocivic, 4:20 PM 12/20/2002]
Old 12-20-2002, 07:35 AM
R@mon's Avatar
Default Re: 91 civic std. (omahaturbocivic)
ok thanx alot. i will be running integra axles but i figure they are the same diameter.... thanx again.
also, how much should i expect to pay for a hub and knuckle assembly from a junkyard?
Old 12-21-2002, 05:23 AM
VTECVillain's Avatar
You could get a pair of 90-93 Integra ones from JDMHondaparts. This would change over to the correct spline hub and upgrade to larger rotors/brakes at the same time. They are selling them for $99 a pair which isn't bad because it includes the calipers and all.
Old 12-21-2002, 05:54 PM
R@mon's Avatar
Default Re: 91 civic std. (VTECVillain)
i checked the site but they say for pickup only... i live in florida so that wouldnt be possible.....
Old 12-21-2002, 06:09 PM
owen_the_soyboy's Avatar
larry jr. at http://www.importautosalvage.com can help you out I bet, he got me set up great
Old 12-21-2002, 06:12 PM
red civic standard's Avatar
Default Re: 91 civic std. (owen_the_soyboy)
i got knuckles at the junkyard for $10 each for my 91 civic std.
the junkyards will try and sell you the whole front suspension, but you only need the knuckle. your stock brakes will swap onto the new knuckle.
Old 12-23-2002, 08:34 AM
R@mon's Avatar
Default Re: 91 civic std. (red civic standard)
one more quick question. would i need to change the whole kunkle or just the hub?
also if i wanted to go with the integra front brakes what year would i need to source the knuckle from?and would it just bolt on with no problem?
thanx again
Old 12-23-2002, 08:44 AM
R@mon's Avatar
i also found this picture. if i bought just part number 1 could i use my civic 4 speed knuckles and run the bigger hub?
Old 12-23-2002, 08:19 PM
CVC9216's Avatar
That picture is of the bearing. Replacing the hubs, even if it would work, is way more trouble than just buying the whole knuckle. You need to buy the hubs, and new bearings alone will probably cost around $100, not to mention installation.
monzster
03-02-2010 05:51 PM
JJ's civic
Northeast (Sales)
04-01-2008 02:15 PM
likaciv
03-10-2004 03:40 PM
Quick Reply: 91 civic std. (4 speed)
