which ecu should i run with and h22a?
alright i got a 97 accord ex, i got a 97+ jdm h22a. people tell me that i can run my accord obd2 with the motor, but they say it would run like ***, but it would still work. then i hear that the obd2 ecu from the prelude wont run with the secondary when its in my accord......what ecu should i go with? i heard the skunk 2 was pretty good. but i dont want just good i want it to run mint. osme say i should get an obd 1 and use a jumper harness? so what should i run for my ecu???
Re: which ecu should i run with and h22a? (pwr5hift27)
Did you see what i said here?? https://honda-tech.com/zerothread?id=355558 I wouldn't go with a whole SK2 ECU if that's what you're talkin about... Maybe just a prog for one of your ECU's.... There should be nothing wrong with your IAB's not opening up as long as you have everything wired correctly... Peace
Re: which ecu should i run with and h22a? (JDMspecEG6)
obd2 is not as bad as people say.
i have a h22a in my 97 accord obd2 w/75 shot of nawwzzz and i dynoed 240 hp to the wheels.
AEM EMS. Pricey, but great for tuning.
Kenji ECU. He's on this board.
Hondata. They're here too.
Or, would a US Prelude ECU work?
Re: which ecu should i run with and h22a? (Revolveu2)
Otherwise, for or more ECU info running with H22 motors (OBD-1 ECUs), check out what I (and some others) had to say: https://honda-tech.com/zerothread?id=358694
Re: which ecu should i run with and h22a? (H22EK)
obd1 p13 is the way to go.
