vtec not hitting...
Old Dec 11, 2002 | 05:11 PM
blkDOHCsol's Avatar
New User
Default vtec not hitting...
finishing up my jdm gsr swap in a 92 dx, wired everything up right to the ecu.. and when vtec is supposed to hit i get a check engine light.. its a 21 (solanoid).. take off the solanoid.. the screen is clean.. the only thing that we questioned when wiring it up is the grounds from the vtec pressure .. it had 2 wires going out but then it did a "T" and split off to 3 wires.. we only imagined that it was another ground.. we grounded both black wires and assumed the blue was the power..
Old Dec 11, 2002 | 05:16 PM
keebler65's Avatar
Default Re: vtec not hitting... (blkDOHCsol)
have you checked this thread yet by kamin? its a list of common things that could be wrong stopping vtec from working.
https://honda-tech.com/zerothread?id=164863
Old Dec 11, 2002 | 07:09 PM
blkDOHCsol's Avatar
New User
Default Re: vtec not hitting... (keebler65)
ya.. its not any of those problems.... :/
Old Dec 11, 2002 | 07:13 PM
Lysawy's Avatar
blue black wire is the vtec oil pressure sensor i thought you don't have to wire that up cuz jdm ecu's don't look for that but i wired it anyway directly to the ECU
Old Dec 11, 2002 | 07:44 PM
blkDOHCsol's Avatar
New User
Default Re: vtec not hitting... (Lysawy)
ya thats the one that is bieng brought to the ecu.. i was thinkin blue, but its blue/black.. i did take a wire from my + terminal and hit the solenoid, it does "click" i have enough oil.. temperatures are right...
woudl this have anything to do with it? my radiator fan isnt kicking on.. and the temp meter is well over half way when idle.. my heat doesnt work unless im in gear and driving around.. i have replaced the thermostat.. got a delsol dual core radiator and replaced my heating hose, upper and lower radiator hose..
Old Dec 11, 2002 | 08:16 PM
Kamin's Avatar
so your getting a CEL 21 when vtec is supposed to engage?
replace the solenoid with one you KNOW vtec works on
Old Dec 11, 2002 | 08:21 PM
blkDOHCsol's Avatar
New User
Default Re: vtec not hitting... (Kamin)
ya.. thats what im doing tomarrow... whats with the split ground on the vtec pressure??
Old Dec 12, 2002 | 02:47 PM
blkDOHCsol's Avatar
New User
ttt
Old Dec 12, 2002 | 05:03 PM
Kamin's Avatar
did you replace your solenoid yet?
Old Dec 13, 2002 | 07:24 PM
blkDOHCsol's Avatar
New User
yea, that wasnt it either
Old Dec 16, 2002 | 04:48 PM
blkDOHCsol's Avatar
New User
i still have 87 gas in my car due to the previous engine.. could that be causing it?
Old Dec 16, 2002 | 04:55 PM
Kamin's Avatar
i highly dobut it
did your code 21 go away yet?
Old Dec 18, 2002 | 04:20 PM
blkDOHCsol's Avatar
New User
nope..... im lost...
Old Dec 21, 2002 | 11:57 AM
BoostedSi's Avatar
Old Dec 21, 2002 | 12:14 PM
blkDOHCsol's Avatar
New User
Old Dec 22, 2002 | 08:24 PM
95hbMatt's Avatar
woud this have anything to do with it? my radiator fan isnt kicking on.. and the temp meter is well over half way when idle.. my heat doesnt work unless im in gear and driving around.. i have replaced the thermostat.. got a delsol dual core radiator and replaced my heating hose, upper and lower radiator hose..
with those symptoms it sounds like a bad waterpump or something....does anybody know a troubleshooting tip to see if it's working? you might want to check that out??
Old Dec 22, 2002 | 08:58 PM
jdmrhdbb2's Avatar
Default Re: vtec not hitting... (95hbMatt)
Double check your Vtec wire. Make sure your vtec wire has continuity from the plug at the solednoid to the wire at the ecu by unpinning it . check for a broken pin . How did you wire it up? Did you try to pin it through the connector at the strut mount and try to do it like the factory and misplace the pin in the wrong location. what gauge and what grade wire did you use, Check if you soldier the wire if it had too much soldier and if its actually the flux inside caused a resistance. Did your crimp go bad. Check the actual pin at the solenoid and see if its bad. Do a continuity test on the solenoid by actually stripping a section of wire near the end of the wire that goes to the solenoid and check it. If you want to test the solenoid the with the car off put your ear near the solenoid and run a wire to the soleniod and just tap it to the battery's posotive terminal not too long. You should then hear a click. the have a freind rev the car 4000-5000 rpm and the just for a second put the solenoid wire to the posotive terminal. You should hear the vtec engauge the lost motion assembly. That teltale vtec noise should be aparant to you. If everything is still no good put the ecu in another car the the code should be gone unless its a singlecam car then in that case you just get a knock sensor code. if that fails then I will research this some more but I never heard of it not working unless the car alreadr had something like a vtec controler and the cut the wire in the wrong place,I only saw that once and the dude cut and tapped the wire way up the harness damnnear to the firewall grommet. If you still dont get results call me on Tuesdaybetween 9AM est and 6PM est but not between 1-2 PM because thats my lunch and I wont be there. I will run over more technical procedures you can try. My name is Hugh and I work at Mahdavimotorsport's in Atlanta the number is 770-923-1550 and tell whoever answers its a question from Honda-tech and I will fax you what ever diagnostic troubleshooting procedure you need free.
Old Dec 23, 2002 | 09:32 PM
WhiteRiceR 4's Avatar
Default Re: vtec not hitting... (jdmrhdbb2)
Ive got a similar problem. I have no V-tec when my engine is cold, and the rev-limiter hits at 7200 rpm's. once the engine warms up im fine thoug... weird
Old Dec 23, 2002 | 11:19 PM
Kamin's Avatar
Default Re: vtec not hitting... (WhiteRiceR 4)
um thats because its supposed to do that
it protects the engine because ITS COLD.
dont go near vtec till the car is fully warm.
Old Dec 24, 2002 | 11:49 AM
topsekret's Avatar
ok so what if the code 22 is on as soon as u turn the ignition on ive used two different ecus and they both send the code please help thanx adam
[Modified by b18vtec, 9:09 PM 12/24/2002]
Old Dec 24, 2002 | 01:44 PM
JD_B18CDX's Avatar
Default Re: vtec not hitting... (b18vtec)
It means there is an open circuit going to the Oil presure switch
OR
oil persure switch is broken.
Check continuity on the wires and the 2 wires from the Oil presure switch.
wolf95
16
Sep 5, 2010 08:25 AM
fongck88
Jan 21, 2009 05:29 PM
fryman
Sep 24, 2008 10:07 AM
im a monster hehe
Dec 24, 2003 11:12 PM
iwhichisme
Dec 9, 2002 10:32 PM
