Are DOHC mounts stronger than SOHC?
Old 12-12-2002, 04:39 PM
DOMKID's Avatar
Default Are DOHC mounts stronger than SOHC?
EDIT
Modified by Dominican_Kid at 4:18 PM 7/1/2003
Old 12-13-2002, 09:15 AM
Katman's Avatar
Default Re: Are DOHC mounts stronger than SOHC? (Dominican_Kid)
Im almost at the point of putting a 97 b18b in my 98 Civic EX. I wanted to know if it would be worth it to purchase SI motor mounts, not the brackets, but the actual mounts themself. I know you can use your stock SOHC mounts but would it be better to use SI mounts? thanks for any info.
Your 97 DX mounts and Si mounts are exactly same sh*t. One thing I do suggest is that you get the Place Racing timingbelt-side rubber mount. The Si and 96-00 CX/DX timing belt (rubber liquid filled) mount tends to rip over a period of time, and the Place Racing mount is the remedy. You can also get motor mount inserts if you'd like reinforced engine mount support.
Old 12-13-2002, 10:07 AM
New User
9KRacer's Avatar
Default Re: Are DOHC mounts stronger than SOHC? (Katman)
Thanks
Old 12-14-2002, 01:28 AM
H22EK's Avatar
Default Re: Are DOHC mounts stronger than SOHC? (9KRacer)
HCP engineering also has an aftermarket mount fo this too!
Nova_Dust
03-14-2008 04:40 PM
dwerpk
12-25-2006 11:22 PM
PYITR821
04-20-2004 09:35 PM
ITRswapandslow
02-12-2004 01:51 PM
0554
10
03-05-2003 10:29 PM
Quick Reply: Are DOHC mounts stronger than SOHC?
