anybody on here road racing a b16? doesnt matter in what honda, just need to know a few things.
if you are running the b16, which cams are you using, have you been able to test on track which cams work best, im talking about stock compression, maybe a little higher, lets say half a point. also what track are you running the b16 on, a longer track with straightaway speeds in the high mph range, or smaller tight turning track, im not decided on which cams to run, b16 cams, or type R cams, but will the lower compression have an affect on the slower speeds of the pistons in the b16 relative to the type R cams?? someone must have tried the 2 cams on here, even on open track days, i dont care for peak hp here, i want that lower and mid range, thanks.
Re: anybody on here road racing a b16? doesnt matter in what honda, just need to know a few things.
type R camshafts are desinged fo 'R'acing
arnet they?
see this graph, can you say "midrange"
BLUE LINE; 220.9 HP, 141.7 TQ =JUN 3
RED LINE; 208.3 HP, 141.1 TQ =Type-R
GREEN LINE; 215.2 HP, 135.6 TQ = Toda C
cant comment on the reliability of this data as i did not create it.
but is is useful to demonstrate the type R camshafts ability within the midrange..
hth,
t..
PS the type R cam is better than the b16a cam in ALL respects. (except price)
arnet they?
hth,
t..
yea, but theres no comparison to b16 cams, so, that graph is a little useless, anyone else??
ps, its not on a b16, i believe thats on an ls/vtec, so, once again, useless. so im lookin for cams swapped from a b16, going from b16 cams straight to type r cams, including tuning, ive driven a b16 hatch with type r cams and the thing was useless from anywhere below 5000 rpm, not good for a road race car. anyone???
[Modified by bubbajim, 12:07 AM 12/16/2002]
t..
regardless of the type of track, you'll spend very little time in the low to mid range you speak of.
i run stock cams, and spend little time below vtec.
save your money and buy better tires, or go to a driving school. ask around in the roadracing forum, you'll get similar response.
These are from importreview.com
Go there to see dyno plots of other B16A motors
thirteen20CRXSi
12-27-2006 04:51 AM
