90 dx to d16z6 wiring questions
yes, i've searched on it, but i still have some questions. i've got a 90 civic dx and a 95 d16z6. i've connecting a dx wiring harness to the z6. i'm using the z6 intake manifold and the z6 ecu.
1.is the EAVC (dx) same as the EVAP (z6)?
2.what does the idle air control valve on the d16z6 get connected to on the dx wiring harness? i don't see an equivalent in my dx.
3.how do i wire up the dx wiring harness to the z6 distributor? the dx harness has a 6 connector plug with 5 wires, while the z6 distributor has a 8 connector plug with 7 wires. what wires go where and what are the extra two wires?
4.the power to the distributor. which wire from the dx harness goes to which wire on the z6 distributor power connector?
5.is the ect switch on the z6 the same as the thermoswitch on the dx?
[Modified by serious, 4:08 AM 12/16/2002]
dohdoh420
10-30-2005 05:54 PM
cartracin6
11-22-2004 02:07 PM
serious
12-17-2002 08:35 AM
