b20-vtec in CRX
ok im going with the b20 bottom end fully built with a type r head with an obd0 dist. what is all required for wiring this monster up. also for right now im going to be using a pr3 ecu.
your gonna want the non obd dizzy (like you already have) injectors, intake manifold and tb your only gonna have a few wires after that you gotta manually wire using the existing plugs on the itr head and on the o2 sensor and run the wires or get a premade harness from hasport.
what injectors. and what wires are you talking about? oh yeah this is an Si im going to be putting it into.
[Modified by NA CRX Si, 10:00 PM 12/14/2002]
duh i'm a stupid *******, i forgot that you'd still have stock injectors to use, but you gotta have a different intake manifold/tb set up......also the wires i was talking about is the wires needed to run vtec... hasport makes a subharness to make it cake for everybody, but there really isn't anything to it anyways
boooooo-yaaaaaaa !!!!!!!!! see sean i told you
Knock Sensor
VTEC Solenoid
VTEC oil pressure
there may have to be some wires that you need to lenghten like your existing primary o2 sensor for example
JRZ88DX
24
Apr 11, 2010 07:16 PM
