no fuel in piston 4?
runnin check engine code for fuel injsection system , put new injector in and still no fuel hmm? ne ideas it has spark no fuels just that one...95 civic ex bone stock adn it just happened out of the blu
Re: no fuel in piston 4? (racerboyb18c)
I had the same problem in my 3rd cylinder but it was throwing a code 16 which is fuel injector. It turned out to be the injector wire was kinked coming through the firewall and I guess it wasn't getting enough conduction through that point.
Check your injectors to see if they are working. Just take a screw driver put the tip on each injector and your ear on the handle with the car running you can hear them tick if they are working.
Re: no fuel in piston 4? (88_SC_CRX_Si)
if you have a multimeter you can check the injector
i had an injector just stop working a couple months ago
it sucked.
just measure the resistance (ohms) between the 2 prongs on the injector.
[Modified by Kamin, 2:31 PM 1/9/2003]
it sucked.
99siky
12-23-2012 01:55 PM
