crank speed sensor necessary? asap please, thanks
I am putting together my b16a2 block and realized I don't have the CKF sensor circuit for the oil pump. I'm going ot be running an OBD I ecu and was wondering if anyone has had experience not running this sensor, or if it is necessary for the car to run.
Re: crank speed sensor necessary? asap please, thanks (tnbigdawg)
In an OBD1 setup, the ckf sensor is in the distributor. you won't need it as long as you run an OBD1 dist.
Re: crank speed sensor necessary? asap please, thanks (Jared)
well I'm running an obdII distributor with a 98 gsr harness plugged into the stock EG harness.. whats this mean? do I need it? thanks
