PWO or PR3 ECU Im confused????
I dont know what I need to go with, PWO or PR3 ECU. Its (b16a1) going in to a 94 Civic. You can get the engine with eaither ECU. What should I do?
Thanks
Tim
Thanks
Tim
Re: PWO or PR3 ECU Im confused???? (civicvteckid)
If it's the OBD1 PR3 then go for it but if they are both nonOBDs like I'm thinkin then don't get either.... You'll be best off with either the XSi OBD1 PR3, a P30, or a chipped P28.... You say B16A1, what year is that from... If it's atleast a 92+ the axles and halfshaft will work just fine.... You aren't refering to use the stock Civic axles right... hehe just makin sure... Latez
if using OBDI electronics then OBDI PR3 or P30 or chipped p28
if you are rewiring and using the nonobd electronics then PR3 or PW0 either one, i persoanlly prefer PR3 as more chips are avlaible and tunning options.
Charlie Moua
10
03-14-2010 08:50 AM
border919
05-16-2009 07:44 AM
prestidge81
07-18-2007 12:47 AM
