LS Side Engine Mount
Old Dec 16, 2002 | 08:06 AM
89JDMcrx's Avatar
Default LS Side Engine Mount
Alright, I removed the LS Side engine mount and im replacing it with the SI mount. Do i have to order the civic si bolts or can i use the LS?
Old Dec 16, 2002 | 09:31 AM
Kataku2K3's Avatar
Default Re: LS Side Engine Mount (97exracer)
The LS are the same and will work fine.... Latez
Old Dec 16, 2002 | 08:21 PM
ef ect's Avatar
if this is for a 97 then reuse factory studs ls ibeleave have a longer un threded part on them you could use a stack of washers but that would be getto . It would how ever set you back a day to pres them out and press them into the new mount, unless you have the stuff to do it. I sugest buying new ones thats what i did its only like 10$ but if moneys tight then do what flotes your boat
Old Dec 17, 2002 | 02:04 PM
Tuan's Avatar
Default Re: LS Side Engine Mount (JDMspecEG6)
Yes the LS engine is the usuable, but the LS and the SI engine mounts and leg, are different. but will both work if used the leg and mount combo
Old Dec 17, 2002 | 08:48 PM
89JDMcrx's Avatar
Default Re: LS Side Engine Mount (Tuan)
ok im just going to order the civic studs. Save me the trouble
Rhymenoceros
Mar 16, 2007 09:47 PM
Rhymenoceros
Southeast (Sales)
Mar 16, 2007 08:57 PM
llama003
Aug 25, 2006 03:23 PM
k24a4kid
Jan 5, 2005 04:41 PM
brent_G
Jul 3, 2002 12:18 AM
