Muscle car Guy needs help from Former Prey
Re: Muscle car Guy needs help from Former Prey (Jeff C)
Well with cars as you know you are only limited buy budget. But one of the easyest and cheapest ways to go is the B16a1. This is from a Civic in Japan. And any of the B series motors are easly and "cheaply" swaped in. They range for the DOHC VTEC B16, B18C1 & B18C5. They are all very good motors and make great horsepower for the size. From 160hp to 195hp. They are all "bolt in" too.
If that does not satisify your need for speed then you can go a little more exotic and swap in a H22. That motor makes 200hp and 160ft lbs. That is a Torquey motor (for honda). I just finished doing one of these in a 1996 civic. It was "easy". The hardest part was the wiring. And that has to be customized. There is A LOT of work. Just take your time and label EVERYTHING!! You do need to purchase a mount kit for this swap too. That car will move quite well!! I hope that helped.
New User
Re: Muscle car Guy needs help from Former Prey (MusclecarGuyhasHonda)
Hehehe,
I used to own a Dodge Ram Charger and a 68 Camaro so no worries
The best engine swap into that Honda chassis is any of the B series engines. B16, 18 or 20. Of all the various flavors the best bang for the buck in my opinion is the B18C1 (Teg GSR engine) the B16 is cheap, plentiful and makes power on the high end but the lack of torque will irritate you (particularly with your familiarity with V8's) the B20 is a great platform to develop and has lots of torque but is sort of lack luster in stock form. The B18C5 (Teg Type R) is the best B series engine in stock form but being the mother of all B series engines it COSTS like a mother as well.
The H series from the Prelude is also a good swap canditate but has its own set of issues and isn't directly bolt in.
Hope this helps
Mike
Hope this helps
Mike
Re: Muscle car Guy needs help from Former Prey (KENLUDE97)
Well I suggest getting a coupe and start your project there. A 4dr is just a waste of time in my opinion. I'm sure you'll be happy with any B series motor but I prefer the VTEC motors over NONVTEC.
If you're willing to build a motor cheaply, Try one of those hybrid setups such as LS/Vtec or CRV/Vtec. It's a NON-Vtec block with the VTEC head. This combo makes for a good low-end/top-end power.
I myself have a LS/Vtec that I built myself from a bare block and from the ground up. The build up of my engine only took about 2 weeks but would of been a lot quicker if I didnt have to wait on parts .It's pretty easy to do, and with the help of Honda-tech I'm sure you can accomplish it yourself.
Re: Muscle car Guy needs help from Former Prey (tnbigdawg)
Re: Muscle car Guy needs help from Former Prey (Slopoke)
Welcome to honda-tech!
Youll see we arent like the average honda/import board, alot of owners on here own muscle cars.
I will be purchasing a 69 chevelle SS in a few weeks so ill be making my first venture into the world of domestics hehe.
anyway, I would go with an engine swap.
for about 3000$ you can put an integra GSR motor in and it will make that 4dr a fast honda.
http://www.hmotorsonline.com
http://www.passwordjdm.com
http://www.jdmhondaparts.com
those are some places to start looking if you want to swap.
I would highly advise a swap, If you turbocharge that POS DX motor, you will make about as much power as the swap, but run the risk of decreased reliability.
Actually his 4 door dx is lighter than both the ex coupe and the si hatch, so I would consider it a perfect canidate for a swap. It makes for a nice sleeper too.
4 door dx is a GREAT sleeper
oh yeah, a b-series swap is better then the h-series swap (personal opinion). but it's up to you though.
Re: Muscle car Guy needs help from Former Prey (sleeperciv)
Thanks for all the Feedback peeps..
if the wiring has to be drasticly modified, then the H22 is out.. Thats too much work. i was thinking about a B series Turbo.. do the B20's spin as high as the others? and should i replace the clutch with something better if i get one of those 30k mi JDM motors? my shifter is pretty sloppy aswell, i'm thinking about getting something aftermarket.. what types are there? how much do they usually run?
why is the Si so much heavier? is the motor that much heavier? my civic is 3245lbs (says http://www.astro.umd.edu/~petitpas/C...vic/specs.html)
Hows do i go about getting a disk brake setup for the rear of my car? i've got rims in the works for spring(17's), what are the biggest slicks you can fit under one of those?? the windows are getting tinted black (car is metallic black).. kinda going for a low profile look....
zach
zach
look here:
http://www.edmunds.com/used/1992/hon...tml?id=lin0066
i think see what it is...that site you're looking at seems to have accidentally put "3" instead of "2." for instance, a civic shown as weighing "3200" lbs should actually weigh "2200" lbs.
[Modified by PPen131, 7:29 AM 12/24/2002]
the B20's have a lower redline but it has good low end power. Combined with quality internals and a vtec head would be great as well as increase higher RPM stability-Depending on your Engine Management of course. If you plan on turbocharging, might as well change the clutch while the engine is out. I think I've heard people saying that the GSR trannies works well with turbo. Shifter, I think the short throw shifters run about $30-100+ because there are cheap ones, and there are quality ones. People recommend getting the steel shifters over the aluminum ones because of strength.
As far as rear disc conversion, do a search because it can be aquired from a number of different cars.
id go with an LS motor (b18b) if you want to boost it
yes replace the clutch, I have an Action 6puck and i LOVE IT, i can get you a good price on one if your interested. it engages like stock but grabs, hard.
it was going to be used on a b16 turbo but im now selling my car.
shifter is fine as stock, just get a shorter shift ****. the stock civic ones sticks up like 3 or 4 inches.
the SI is heavier from all the extra crap they put in it, ABS, sunroof. power everything, etc etc. all that little crap adds up.
Yea, you could get an LS (B18A or B) and then get FFGeoffs turbo kit...that should rock.
I would get some 15 or 16" wheels and tires cause you are going to want a meatier tire than what is avaliable for 17" wheels. I would say get some Rotas, stock 99-00 Si wheels, or stock GSR wheels then put some 205/50's on them.
On the rear brakes, I am not a 5gen civic dude, but I would say you can get the entire rear trailing arm assy from a 94+ Integra and swap them over to your civic.
That site is showing gross vehicle wight. I guess that's the car's maximum rated load...you know, with like 5 passengers.
Try checking out Import Builders at http://www.importbuilders.com
They can do about anything, and are reliable, make good power, and know what they are doing.
Check around their parts lists and prices. You'll see that they have stock rebuilt B16A's for sale as complete swaps. They also can custom buld an engine combo for you, plus buld it for turbo, N/A, nitrous, whatever.
Welcome to the Honda club. My tech guy has been bulding street rods for 30 years, and I have finally opened his eyes to the power an potential of imports and 4-cyinders in particular.
And, I also have a weak spot for old Mopars and AMC's, especially the 69 Chargers, Challengers, and the AMX.
Just because we drive Imports, a few of us on this board realise there are more cars out there...
Sushi Buffet Champion
Re: Muscle car Guy needs help from Former Prey (GapxGuy)
Muscle;
You are not the only V8 guy who visits here. I've got a 64 Chevelle 2 door wagon. As long as questions posted here are about Hondas, then everybody seems helpfull and friendly. Heck, "car guys" are "car guys". I'd even be willing to talk to somebody that owns a Ford.
My recommendation for you would be to check out a B18B swap out of an LS integra. Although the B18C is a better (higher RPM) engine, they get rather costly.
Count on getting a "mount kit". Try Hasport or Place Racing. (If you want to start a long, angry, string then all you have to do is ask which is better.)
The wiring is an "issue", but others in the past have been able to do it. If you are not good at figuring out a wiring diagram then it may be best if you just pay to have the loom modified for you. Hasport and Place are both places where you can have this done.
Re: Muscle car Guy needs help from Former Prey (Wes V)
Thanks for the input people.. although i'm sure that i am capable of doing the whole swap myself, (can't be THAT much different, just more **** in the way) lately i've been extremely sick of working on ****.... so i'll probably have a buddy do it.. or take it to a shop... i've decided i'm not going to go with a turbo right away.... it prob wouldn't be as fast as my shelby anywaz..
what sort of wiring changes have to be made? i took Electronics in Highschool so i'm sure i can figure it out... but don't really feel like ******* with it so i might just have it done like someone suggested..
Once again, thanks for all the input.. Hope everyone is having a good Christmas!
You can find wiring diagrams, and ECU pins at:
http://tech.hybridgarage.com/tech/index.html
And a how-to is at:
http://www.c-speedracing.com/howto.php
And a how-to is at:
He's got a 5th gen, he doesn't need a mount kit.
If you're going to boost it, I'd put my vote in for a B18B. If you're not going to boost it, and you just want some power to your daily driver, then B18C1 (USDM GSR Engine) or hydro clutch JDM B16A. Both of which are bolt in and have stock reliability.
As someone already pointed out:
http://tech.hybridgarage.com/tech/5gtech/index.html
