b18a or b18b...
Old Dec 18, 2002 | 05:34 AM
SupaFly_Honda's Avatar
Default b18a or b18b...
deciding on which block will work best for an ls/vtec? and why? Or are they the same?
Old Dec 18, 2002 | 10:58 AM
Kataku2K3's Avatar
Default Re: b18a or b18b... (SupaFly_Honda)
They are the same basically the same... If you are rebuilding with new bearings, pistons, etc. I would just stick with the B18A cuz it's got a PCV system built into it.... Peace
Old Dec 18, 2002 | 02:42 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: b18a or b18b... (JDMspecEG6)
yeah, basially the same, id say if yer going to build the bottom end, get a B18a, being thats its prolly cheaper, and if yer going to keep the bottom end stock, get a fairly newer B18b, but thats just my $0.02..
Old Dec 18, 2002 | 05:10 PM
StorminMatt's Avatar
The only real differences between these two motors are in the top end. So if you are going LS-VTEC, neither holds an advantage.
Old Dec 18, 2002 | 06:22 PM
Adriano's Avatar
Default Re: b18a or b18b... (StorminMatt)
the b18a are 10hp less from factory. The 90-01 b18a is obd0, while the 92-93 b18a and 94-95 b18b are obd1. The 96-01 b18b are obd2. Just get the one that has the right odb-x for your car, it will save you some headaches.
Old Dec 18, 2002 | 07:03 PM
VTECVillain's Avatar
Default Re: b18a or b18b... (brryder)
That's really not a big factor when building an LSVTEC considering that all of the OBD components are focused more on the head than the block. If you use a nonOBD or OBDI block and plan to go OBDII, all you need to do is use an OBDII oil pump with the crank fluctuation sensor.
Old Dec 19, 2002 | 09:02 AM
Thanks guys.
JDMspecEG6...what is the PVC system?
Old Dec 19, 2002 | 05:38 PM
Kataku2K3's Avatar
Positive crankcase ventilation... When your motor is running air and fuel can leak through your rings which goes down into the crankcase this is known as blow by...... What the PCV system does is flow air through the block in order to get rid of this gas which can break down your oil... You'll notice a breather port at the top of the valvecover which is connected into you intake... Air is sucked through it which flows down into your block -> gets that bad gas vapor out and runs it to the black PCV box on the back of the older style LS blocks where it is separated from the oil and purged into the intake manifold where it is sucked into the motor and burned up... Hope this helps... Latez
latinf86
Sep 5, 2006 02:04 AM
methodz55
13
Apr 11, 2006 07:15 AM
effinnwackk
21
Jul 1, 2005 05:50 AM
Tammy_EP3
Oct 16, 2003 02:12 PM
CRXSleeper
17
Sep 17, 2002 06:42 PM
