Putting a 95 D16Z6 into my 00 Civic, why won't it start?
As the title states I put a 95 D16Z6 into my 00 Civic EX which had a D16Y8 originally. I swapped out the intake manifold, injectors and distributor. There was a sensor wire coming from need the crank pulley that the Y8 had, but the Z6 doesn't. I am still using the 00 harness and ECU so that wire is not connected.
Could this cause my engine to not start? The motor has probably been sitting for a year or so, so maybe that could be the cause too. I am lost on ideas and I need to get this thing running.
Thanks in advance for all your help.
Re: Putting a 95 D16Z6 into my 00 Civic, why won't it start? (GS-RoJa)
check the small stuff first. sparks, fuel, cable order, go back and check it again.
f@sth@tch89
09-23-2018 05:58 AM
kpenderg
08-28-2016 04:58 PM
ilovesd90macs
01-26-2011 07:35 PM
aznboiek9
05-30-2009 11:26 PM
