Check engine light
Old Dec 12, 2002 | 07:28 PM
zlambe's Avatar
Default ECU codes
Check engine light comes on since B16a swap. how can I draw codes fron the ECU?
[Modified by zlambe, 4:37 AM 12/13/2002]
Old Dec 12, 2002 | 07:52 PM
Chiclets's Avatar
Default Re: ECU codes (zlambe)
what kind of car did you do the swap into year and model
Old Dec 12, 2002 | 08:00 PM
zlambe's Avatar
Default Re: ECU codes (bluedemon)
90' Civic HB DX
Old Dec 13, 2002 | 08:44 AM
Turbo88hatch's Avatar
Ok you look at your ecu and there should be a little red light flashing on it.count how many times it flashes and get yourself a manual and it should tell you what the error codes mean.I've done it in B16a1 powered 88 civic DX.if you need the european crx sir that came equipped with the B16a1 just email me and i'll get it for you.(vegitastorm@yahoo.com)
Old Dec 13, 2002 | 04:19 PM
zlambe's Avatar
Default Re: ECU codes (vegitastorm)
The ECU does not have the red LED in the top of it.
Old Dec 13, 2002 | 07:45 PM
VTECVillain's Avatar
What's the code on the side casing of your ECU?
cuseikan
Aug 18, 2008 01:26 PM
racerxfactor
14
Jun 15, 2007 06:59 AM
Project_EK
Aug 13, 2005 04:08 PM
naptownrex
10
Apr 18, 2005 08:26 PM
jason_alt
Mar 3, 2004 07:08 PM
