swap problem
So im in the process of swapping a B18b into my 89 CRX SI and i have the hasport mount kit , so i go to put it in and the drivers side mount sits crooked , you slide it over the studs on the block and it should go in parrallel into the brace on the car where the bolt goes through , but it sits on a angle. Anybody else have this sorta problem ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">your motor is a 92, your car needs a 90-91 engine bracket. theres no way out of it.</TD></TR></TABLE>
The 90-93 Integra driver's side mount brackets are the same part. The same engine bracket was used across the DA chassis through those years. The major difference in the 92-93 Integra as opposed to the 90-91 was the switch from OBD0 to OBD1.
see this is where im confused , it has the old ribbed valve cover , it says 92 on the block ,but it says b18b on it .
But if it says b18b on it it had to come outta a dc integra as far as i know
CW-ITR
13
Mar 27, 2007 11:34 AM
spooncivicsi
Welding / Fabrication
May 6, 2005 06:28 AM
