fuel pump question
Old Mar 10, 2004 | 08:36 AM
89 JDM CRX's Avatar
Default fuel pump question
will the stock crx si fuel pump run a stock b18b engine ? or will i need to throw something else in there?
Old Mar 10, 2004 | 11:41 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: fuel pump question (89 JDM CRX)
i would upgrade to at least a 190 lph or a 255 lph pump, just depending on what your setup or future plans are. less than 200 hp, 190 lph is fine. 200+ hp then a 255 lph is good.
Old Mar 10, 2004 | 12:02 PM
89 JDM CRX's Avatar
Default Re: fuel pump question (vtecb20coupe)
basically just for now to run my bone stock b18b is what i am wondering , im going turbo but i already got the 255hp pump for that. its just for a couple weeks to run around on the b18b to work out bugs and such before turbo
Old Mar 10, 2004 | 05:30 PM
saleensolution's Avatar
i had a ls/vtec boosted running 10psi on a stock hf fuel pump with no problems. but i would not suggest doin it if you plan on turboing your car go ahead and put a pump in it
Old Mar 16, 2004 | 09:52 PM
89 JDM CRX's Avatar
Default Re: fuel pump question (saleensolution)
basically all i want to know is , will my 89 crx si fuel pump be enough to support my stock b18b ?
Old Mar 16, 2004 | 11:40 PM
hondaZvic's Avatar
yes, ur b18b will run off of the 89 crx si pump.
but might as well upgrade the pump if ur gonna or already have swapped the motor right?
Old Mar 17, 2004 | 10:13 AM
B A N N E D
Default Re: fuel pump question (hondaZvic)
yes, it will work. the non vtec pumps are the same.
stevn
Jul 5, 2007 01:07 PM
tkHBseries
Feb 14, 2004 07:01 PM
2000CX
14
May 13, 2003 01:49 PM
g_man80
13
Sep 20, 2002 11:12 PM
97hb
May 9, 2002 02:47 PM
