B18B into 96-00 Civic, Driverside mount need change?
Will the driver side engine mount from the b18b work on a 96-00 Civic? or will I have to get one from a 99-00 Si to make it work? (im talking about the mount on the engine with two studs on it)
TIA
TIA
Re: B18B into 96-00 Civic, Driverside mount need change? (Turbo_Siii)
You will have to have the one for a 99-00 Si. it attached to the block using 3 bolts and then has the 2 studs. You also use the stock metal bracket that attaches this hard mount to the oil filled mount. Get me???
I couldn't just use the stock medal bracket that attaches to the hard mount to the oil filled mount to the stock LS mount thats already on the block?
ChinitodeNJ
11
08-10-2009 01:45 PM
97civicdx
01-03-2005 06:32 PM
VTC_CiViC
05-17-2004 01:24 PM
