help!!! engine bogs when i shift over 5500 rpm
i have a 2000 civic with a b18c1 tried both 99 civic si and a p72 ecu. used the engine harness out of a 99 si and only have cel with the si ecu the p72 has no cel. everything seems fine have good idel runs well until i start to push it. when i hit high rev and **** over 5500 the engine leans out and stays lean until you let off the gas then it recovers and is fine until you go to shift or it you are in high rev let off the gas and hit hard it does the same please help have tried many things but don't know what to do anymore
Re: help!!! engine bogs when i shift over 5500 rpm (doublejz)
replaced pressure switch already and have no cel with p72 ecu
also checked the wires used brand new 99 civic si engine harrness
שלבי עבדו
10-30-2016 07:14 AM
D.deem94
13
06-26-2013 09:02 AM
zildjianmatt
02-11-2010 07:09 AM
topnotchn20
03-20-2009 11:45 AM
