d16z6 into eg, do I need to remove the axles from the hub?
What is the easiest way to put a z6 in my dx hatch (new engine and tranny, but same axles)
can you drop the axles while still being attached to the wheel?
Re: d16z6 into eg, do I need to remove the axles from the hub? (yusoslo)
hehe, sounds like you have a learning experience ahead of you. You can't pull the tranny or engine with the axles still attached, and you can't remove the axles with the wheel still on. Theres a huge axle nut you gotta take off dead center of the wheel studs. It'll be a really easy swap though. Will mount drop straight in and be pretty much plug n play. Your gonna have to extend the wire from the shock tower for vtec.
Re: d16z6 into eg, do I need to remove the axles from the hub? (doublejz)
yeah i know about the axle hub nut, I was just hoping by loosing the suspension I could slide the axle out of the tranny.
I just hate dealing with those stubborn nuts I dont have an impact
aahh i gotcha, dunno, you might be able to if you unbolt the for or maybe even the control arm. Never tried it though
alldemtingz
16
06-17-2011 10:13 PM
Capt. Jimbo McSubipants
09-15-2005 11:26 AM
teknohatchie91
12
05-01-2005 05:38 PM
