b18a dumb question...
Old Mar 6, 2004 | 08:12 AM
JohnnyM's Avatar
Default b18a dumb question...
Picked myself a b18a up and have it on an engine stand. I was cleaning it up getting ready to paint the block and noticed that the crank pulley seamed really easy to turn. I do have the alternator off so no belts around the pulley. Should it turn easily while the crank pulley bolt remains fixed? If not, what am I missing?
Old Mar 6, 2004 | 11:55 PM
Fobtions's Avatar
Default Re: b18a dumb question... (JohnnyM)
is there spark plugs?
Old Mar 7, 2004 | 10:34 AM
JohnnyM's Avatar
Default Re: b18a dumb question... (Fobtions)
Yes... How would that matter? No distributor at the moment...
Old Mar 7, 2004 | 11:20 AM
civic type B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyM &raquo;</TD></TR><TR><TD CLASS="quote">Yes... How would that matter? No distributor at the moment...</TD></TR></TABLE>
It is important to know if the plugs are in there because the plugs seal the combustion chamber, and would make it markedly more difficult to crank the engine by hand. Last week I had my b16 apart on my engine stand, with no head or accesories on, it turned readily with minmal effort, at the flywheel.
If you are turning the engine by the crank pulley, which would be more diffucult (leverage) than the flywheel, something might be wrong. Do a compression test.
B
Old Mar 7, 2004 | 02:05 PM
JohnnyM's Avatar
Default Re: b18a dumb question... (civic type B)
The crank pulley bolt does not move. Only the pulley. Is there some locking pin I am missing?
Old Mar 7, 2004 | 05:48 PM
JohnnyM's Avatar
Forget about it. Crank pulley wasn't even tight. Thanks for your guys help....
rogue420
Jul 20, 2008 06:55 PM
SpazMan
Jun 5, 2008 10:55 PM
xpbuddies
Feb 5, 2007 08:02 PM
Nicaraguense13
Oct 2, 2006 12:20 PM
david90
Aug 20, 2003 03:24 AM
