need to know what plug goes to iac sensor on gsr engine
i'm using a d16z6 harness and theres one sensor that has a 2 wire prong and theres no wire for it where does it go to ???
Re: need to know what plug goes to iac sensor on gsr engine (Greg456)
your post is kinda vague bro but if you just finished the swap from you original harness there are two plugs that will fit onto your iac, one goes there an the other one will go to a sensor that is usaully mounted on the fire wall, not really sure what your askin for though, there is also a plug that will not be used on the swap.
B18CivicEH2
09-10-2007 07:10 PM
