JDMB18CR into LS Integra
The car was originally a 95 Integra S.E., with a automatic transmission. My friend and I dropped in a JDM B18CR motor, which is OBDII. My question is, am I suppose to change the harness that goes from the shock tower to the ecu, or will the original one work? Thanks.
Re: (mtber)
Well, my friend reused the original engine harness yes, but he said he had to splice wires here and there in order to match the sensor on the new motor. However, we ended up haveing 4 plugs by the shock tower, when from what I can remember on integra's there are 3. Also, we are using a P72 ECU, and my friend said that the wires do not match up from the LS ecu harness with GSR/Type R ecu harness's.
tuningrookie
05-03-2007 04:53 PM
