Can I use an OBD2 H22 distributer on a F22b Sohc vtec
Can I use an OBD2 H22 distributer on a F22b Sohc vtec??
I'm in a bit of a stickey situation and need to know is this will work.
also does the obd2 h22 distributer have the crank angle sensor in the distributer or is it in the oil pump....I need it in the distrubuter
What I'm attempting to do is put and OBD1 F22b SOhc vtec into a 97 Honda odessy
that had a obd2 f22b6 sohc non-vtec. So basically converting the F22b to obd2
thanks
Chris
Modified by b17a1teg at 4:55 PM 3/5/2004
thanks
Chris
