What does my H22 TURBO need, not WANT, need in order to run?
What does my h22 turbo need in order to run good for daily driving and a little bit of
street play. Ok, a lot of street play. This is what I got guys and I am getting mixed
input on what to do. I have a 1993 honda civic dx 4dr with a 97 h22 motor in it that
originally had an auto trans, but now has a manual prelude tranny, I believe the
motor is usdm. I think I am running stock gsr injectors which are 240cc cuz there is
no resistor box on my setup. I have megan racing adjustable cam gears, stock
intake manifold and throttle body, motor is a stock block, head hasn't been touched
either. Running an aem fuel rail with aem regulator. I have a t3o4 hybrid turbo setup
(.48 a/r and .60). Equal length manifold, with tial wastegate set with a .4 bar spring
which is 6lbs and a tial blow off, a spearco style intercooler, 2 step boost controller, 2
inch thick radiator, fidanza lightened flywheel, act stage 3 clutch, 3 inch downpipe to
a 2.5 inch exhaust all the way back. No cat. The car has just been turbo'd like I
haven't even drove it yet, its still in the shop. Before you flip out about my injectors,
I do have 450cc dsm ones that are gonna be installed along with a low impedance
resistor box. Here's my question, i have a p06 that was chipped to a p13, and im
running hondata s200 with 3step and datalogging. This is a stock motor and will only
be boosting a max of 9lbs if that for now. What do I do for hondata purposes, do i get
the boost option with the 3 bar map sensor, and extended 6 colomns they add to the
fuel and ignition tables, or do i stick with what i have, since the stock map sensor will
read all the way up to 11 lbs of boost before throwing errors? And whats the best and
cheapest way to get it tuned right? Do i need rom editor and that romulator device?
Should i just have it taken to a dyno, or have it street dynod using a wideband? I
dont know where to go from here as hondata is concerned. Please help. My screen
name on aim is spoolingpower. Any ideas are most appreciated. I also have pictures
upon request.
Modified by spoolingpower at 8:12 PM 3/14/2004
upon request.
street_ride14
10-10-2009 03:32 PM
h22turbocivic4dr
03-14-2004 02:58 PM
