h22 EK finally running...
Got the h22 running in my 96 civic today , just a couple quick questions for anyone to answer...whats a good set of springs to put on the shocks i bought KYB agx...one problem i found so far is shifting into 5th gear is a little ruff, anyone expearience this, i have a brand new ACT clutch...linkage problem?? any respone will help, thanks guys
whats average output of a stock jdm H22...
Re: h22 EK finally running... (Ddogz15)
i have 18in wheels stock sturts with sprint springs and my ride is a little bumpy but i like it for what i use it for i only drive it at night and race with it then i put her away so and also my 5th gear is a lil bit hard to find but i think that its just a cable adjustment but im not 100% on that good luck and congrats!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ddogz15 »</TD></TR><TR><TD CLASS="quote">Got the h22 running in my 96 civic today , just a couple quick questions for anyone to answer...whats a good set of springs to put on the shocks i bought KYB agx...one problem i found so far is shifting into 5th gear is a little ruff, anyone expearience this, i have a brand new ACT clutch...linkage problem?? any respone will help, thanks guys
Since you already bought shocks, i would recommend a GCC (Ground Control Coilover) setup with h22 spring rate springs in the front ($128.00 shipped from GC). Thats the spring setup im runnin on mine w/ stock struts and it rides nicely. As far as 5th goes, you may not have trimmed enough off the passenger side mount bracket, that can sometimes cause a rough 5ht gear shift. But I think everyones eg/ek h22 swaps have a lil bit of a rough 5th gear shift.
Re: h22 EK finally running... (AudioFuct)
on eks you dont trim the mount...only on egs...chk the spacing and the condition of the cables...but from what i gather 5th gear on preludes are a bit notchy.
collapsedblkhrt
03-26-2007 04:16 PM
jdmekcivic2eg
19
09-03-2002 12:37 PM
