Anybody have any idea what this is on my IM?
I have no clue what this 3rd nipple is on my h22 intake manifold, its a 2000 prelude type sh engine if that matters. If i try to plug it up itll make my engine stall out and for the pic on the bottom i dont know what that goes to either but its right next to the iab...
Re: Anybody have any idea what this is on my IM? (Vp Special K)
the third nipple goes to your cruise control actuator. the bottom one near the IAB there's no connection. just leave it plugged. if you don't have cruise control plugged and adjust your idle screw. turn it clockwise till it bottoms out then turn it 3 1/2 times this should be done when engine is at normal operating temperature.
That means that you have to adjust the idle screw like he says. All vacumn plugs should be eitehr plugged up or routed to the appropriate area.. Do you have a line running to your charcoal canister. If not then you can run one from that port to the top of the canister..
