HELP - B18C5 into 1996-98 Civic EX
Hi, I have an insurance check coming in for my stolen Si : ( .... and my plans are to buy a 1996-98 Civic EX and immediatly swap in a b18c5 (complete changeover from hmotorsonline), my question is :
What else to I need? special mounts?
What piping/exhaust set-up options do I have?
Thanks ...
Thanks ...
Re: HELP - B18C5 into 1996-98 Civic EX (SiRacer365)
Ne1? Please help? also,
what times should I expect w/ average driver I/H/E .. .? mid 14s/low14s?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRacer365 »</TD></TR><TR><TD CLASS="quote">Hi, I have an insurance check coming in for my stolen Si : ( .... and my plans are to buy a 1996-98 Civic EX and immediatly swap in a b18c5 (complete changeover from hmotorsonline), my question is :
Thanks ... </TD></TR></TABLE>
you need the two lower front mount brackets and rear L bracket from a 99-00 SI.
wiring should be plug and play except for CKF sensor and maybe like two more, have to check.
Use the itr manifold, than get custom 2.5 piping, cause the civic piping is not even 2in. big motor means bigger piping. if you want to get a cat also, get one from an si, not sure if u need to modify it, cause i had an ls one and it was too long.
hope this helps
hope this helps
turnsignalandy
09-26-2007 07:41 AM
GreenD16Y8
04-12-2006 10:16 AM
