00ek dx with a 94 b18b wiring help!!!!!
so my friend is going to start this swap this weekend....i already did a search but couldn't find the anwser i was looking for.....he got the 94 b18b cheap.....so to wiring this obd1 motor into an obd2 car is it hard....can we swap a eg harness into the engine and than woul it be plug n play ......so pretty much what wiring harness would be plug n play for this swap.....
Re: 00ek dx with a 94 b18b wiring help!!!!! (dannydos)
About your only option is to use the stock civic hanress. I would use the stock civic injectors so that the plugs on the harness will match and then you will need to wire up the dist. plug. Just while you have the complete motor laying on the ground then you can lay the harness on it. Start by pluggin up the injectors first and then extend one plug at a time so that it all fits nicely on the motor.
Re: 00ek dx with a 94 b18b wiring help!!!!! (jDmDxTuRd)
Just wire the b18 up with the stock civic harness as suggested and you will need to change the plugs on the distributor. Recommended would be to use a Skunk2 or your choice OBD-2 to OBD-1 conversion harness and run the OBD-1 LS computer.
j4s0n1337
19
07-21-2019 06:47 PM
Cristorey34
08-06-2005 07:36 AM
