Swapping from an ITR to an EG..need advice pls
Re: Swapping from an ITR to an EG..need advice pls (Jdm 98spec R)
Mostly all ITR parts are transferable like motor is a direct plug n play if im not mistaken and suspension will bolt right up with ITR lower control arms. ABS in my opinion on an eg is worthless and I am not sure it would even work.
its not a direct swap though, you have a 98 spec r im assuming, so youll have to go from obd2 - obd1. keep the susp, sway bars, motor tranny, ecu and the 5 lug set up
MOVING SALE!!!!!!front jdm itr susp. parts, jdm itr front sway bar, jdm eg climate control, ricey M3
Bonez21
08-21-2004 09:58 PM
Civic44
07-08-2002 04:04 PM
