best engine to put in a 91 hatchback?
Old Mar 15, 2004 | 12:32 PM
edster013's Avatar
Default best engine to put in a 91 hatchback?
I just bought a 91 hatchback. The engine was bad in so i got it real cheap and want to find out what the best engine is (h/p wise, ) that would fit.
It has a 4speed manual tranny in it , was also woundering if any knows where i could get a 6spd for it, or what type of 6sp would work with it.
Sorry for the dumb questions this it the first import car that ive ever owned.
I appriciate the help.
Old Mar 16, 2004 | 10:21 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: best engine to put in a 91 hatchback? (edster013)
a 6 speed? are you referring to a k series?
Old Mar 17, 2004 | 07:48 AM
paybac4223's Avatar
Default Re: best engine to put in a 91 hatchback? (vtecb20coupe)
well you have alot of options for your hatch....
you can go zc, b series, or h series...
Most honda trannys are 5sp....there are 6sp trannys, however they are found in the k series...and some of the acura sedans... do a search on engine swaps and and within a week or two you will start to get a feel for what direction you want to go depending on your dollars and dedication...
Old Mar 17, 2004 | 09:04 AM
SleepnCiViC's Avatar
ahhh man search you are way to broad in your questioning
Old Mar 17, 2004 | 09:35 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (SleepnCiViC)
broad q's are ok when u are new in my opinion depending on buget i would do a j-spec ITR swap. you can start off like everybody else with a b16 but then you will just spend $$$ on purchasing itr parts for it and in the end it is still a b16 . an in the past we ave seen ef chassis cars (88-91) with stock itr swaps run 13.5s- 12.85's
Old Mar 17, 2004 | 06:51 PM
FATBOYeg6's Avatar
Default Re: (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">an in the past we ave seen ef chassis cars (88-91) with stock itr swaps run 13.5s- 12.85's</TD></TR></TABLE>
really? do you have any proof of that? is it on slicks or street tires? stripped out, or full interior? this is the first i have heard of an ef going that fast with a stock type r.
Old Mar 18, 2004 | 10:00 AM
DYNO-PRO
Default Re: (ninefivehatch)
SURE I HAVE A COUPLE OF PICS IN MY SHOP AND YES THEY WERE ON SLICKS (THAT IS THE ONLY WAY TO RACE) HERE IS HOW IT GOES... A STOCK JDM ITR MAKES APPROX 170-175HP AT THE WHEELS. AN EF CHASSIS IS A LIGHT VEHICLE. WITH A GOOD DRIVER AN EF CHASSIS WITH A J-SPEC ITR AND 22/8/13 SLICKS WILL GO 13.5-12.8 STOCK. IVE SEEN IT WITH MY OWN EYES AND REMEMBER THIS IS JUST MY OPINION ON THE BEST MOTOR TO START WITH
Old Mar 18, 2004 | 08:05 PM
uncle's Avatar
I believe Tom's eg hatchback will run 12's with basically a chipped ecu and dc header.
moz92
Jan 23, 2007 11:38 AM
tico
Jul 10, 2006 05:51 PM
Stillo
Aug 19, 2005 12:03 PM
Stillo
Aug 19, 2005 11:43 AM
s0apgun
Oct 21, 2004 09:44 AM
