88crx D16z6 swap
88crx D16z6 swap
i need help on what im gonna need for a 88 hf crx D15b6 to a OBD1 D16z6. i was wondering what wiring woulnd need to be done and where i could get wire harnesses that i might need.
Re: 88crx D16z6 swap (Amf_crx)
If you are going to use the Z6 ecu, then you'll need a OBD0 to OBD1 wiring harness conversion. Since you have an HF, your wiring will be a little easier than would be if you had a DX. It all depends on what ecu you will be using with the D16Z6
SOHCEK-Turbo
08-12-2003 01:41 PM
