Question about tranny (driveshaft) seal on a car with a swap...
Old 03-10-2004, 05:47 PM
Got Spoool's Avatar
Default Question about tranny (driveshaft) seal on a car with a swap...
I have a JDM b16a swap with a hydro Y21 tranny in an EG hatch. Im using teg driveshafts, and the pass side seal is leaking. The shaft is 6 months old. What would generally cause this? Also what driveshaft seal should be used with that tranny, GSR?
Also, when doing a clutch replacement on this car, what bearings do I need to change.... are they the 'throwout bearing" and "release bearing"? Are they the same for all B series tranny's?
Thanks guys!!!
Please reply asap.
Old 03-10-2004, 07:18 PM
Got Spoool's Avatar
Default Re: Question about tranny (driveshaft) seal on a car with a swap... (Got Spoool)
TTT
Old 03-11-2004, 12:54 AM
Fobtions's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Spoool &raquo;</TD></TR><TR><TD CLASS="quote">I have a JDM b16a swap with a hydro Y21 tranny in an EG hatch. Im using teg driveshafts, and the pass side seal is leaking. The shaft is 6 months old. What would generally cause this? Also what driveshaft seal should be used with that tranny, GSR?
Thanks guys!!!
Please reply asap.</TD></TR></TABLE>
use the tranny seal according to what axle u use.
the pilot bearing on the flywheel is the same for all b-series. there is two throwout bearings available the hydro and cable. u would need a 94-up integra
Old 03-11-2004, 10:22 AM
hypa's Avatar
old tranny seals get hard, and typically will fail after removing the axle. The same thing happened to my tranny, and more recently, in my cousin's tranny.
A new seal fixed the problem. Also, you want the 90-93 integra seal, although they're pretty much the same seal for all B series trannies.
Old 03-11-2004, 12:44 PM
Got Spoool's Avatar
Default Re: (hypa)
hypa:
My tranny is a hydro B series and my axles are 94+ teg axles.
Why would a seal from a 90-93 teg work instead of the 94+ seals?
My seal has been failing 4 times in the past year. 3 of the 4 was due to the wrong seal, so why would the last one fail?
Im very confused.
Thanks for the replies, plz keep them coming.
Old 03-12-2004, 10:23 AM
hypa's Avatar
94 integra axles on an EG hybrid?
I always used 90-93 (DA Teg) axles on my EG swaps, since they are the same as the axles used in the jdm eg SiR2. FYI, I did close to a dozen EG swaps, and used the DA axles exclusively with no issues.
Maybe that's your problem right there?
Old 03-12-2004, 10:35 AM
Got Spoool's Avatar
Default Re: (hypa)
93 axles are for the cable tranny setup.
On hydro trannys, everyone that I know of uses 94+ Teg axles.
Sr420Det
05-11-2010 11:09 AM
aalb1
04-22-2009 05:15 PM
Andrew77
11-14-2007 03:21 PM
AlphaKennyWun
11-28-2002 08:29 AM
Quick Reply: Question about tranny (driveshaft) seal on a car with a swap...
