What clutch and axles
Hey guys hows it going just wanted to know what clutch do I use for my 93 gsr cable tranny and also what axles do I use to make the tranny work in my 91 crx thnx.
Re: What clutch and axles (TheBlackCrx)
umm. you can use a 92 up b series clutch they are all the same do not get the 90-91 clutch though. the axles you can use either 90-93- or 94+ teg just depending on which halfshaft you got. if you use a 94+ halfshaft you willl need to change the axle seal on that side of the tranny get it far a 94+ teg you should be ok
Re: What clutch and axles (saleensolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution »</TD></TR><TR><TD CLASS="quote">umm. you can use a 92 up b series clutch they are all the same do not get the 90-91 clutch though. the axles you can use either 90-93- or 94+ teg just depending on which halfshaft you got. if you use a 94+ halfshaft you willl need to change the axle seal on that side of the tranny get it far a 94+ teg you should be ok</TD></TR></TABLE>
That's it in a nutshell
Mr_CRX
03-14-2004 04:03 AM
