96 civic hatchback B18C5 swap CKF sensor?
Im working on a JDM B18C5 motor swap into an EK. After some prep work on the motor while it was out i switch over the wiring harnesses to do the wire work. I notice the motor doesn't have a CKF sensor the one on the oil pump housing. I belevie its a 96 or 97 JDM integra type R motor. Do you guys now anyithngf aobut this? does the JDM ecu not run a CKF sensor? Well any info would be great thansk guys.
supermotothud
01-22-2009 09:17 AM
