question on wiring IAC sensor ANd iab
using a 92-95 ex harness ona jdm gsr engine and theres 2 two wire sensors on the itb one on top of the TB i think ts the Iab and theres a sensor on the back of the TB in the bottom on my harness theres only one 2 wire connector and i think it goes to the sensor on top but i don't know.
Also i'm using a integra radiator form a 94 integra, on the frame of the car int he front theres 4 brackets two wree for the radiator and the other two were for the ac fan, the ac fan brackets make the radiator sit to high up and it will hit the hood, any suggestions i figured knock them down.
Modified by Greg456 at 7:53 AM 3/12/2004
Re: question on wiring IAC sensor ANd iab (Greg456)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greg456 »</TD></TR><TR><TD CLASS="quote">using a 92-95 ex harness ona jdm gsr engine and theres 2 two wire sensors on the itb one on top of the TB i think ts the Iab and theres a sensor on the back of the TB in the bottom on my harness theres only one 2 wire connector and i think it goes to the sensor on top but i don't know.</TD></TR></TABLE>
The plugs that you are talking about, are they 2 or 3 wire plugs? The sensor on top of the throttle body would be the MAP sensor, the one on the back would be the TPS. The IAB on a GSR is located on a small vacuum canister under the intake manifold.
Re: question on wiring IAC sensor ANd iab (VTECVillain)
they are 2 wire connectors the iab is the one i'm talking about, at the bottom of the intake manifold
davidluko
02-27-2007 06:41 AM
