LS swap into 4g.. axle question
can i use the axles from the 4g civic or do i have to use the intermediate shaft and axles from the integra?
i got a new intermediate shaft cause the one i had didn't fit.. it fits into the tranny but it's a little off on the block.. 3/4" too high for each hole actually.
anyone had this problem?
can i use the long honda axle instead on that side?
Re: LS swap into 4g.. axle question (viridion)
You can't use D series axles with a B series swap, neither side will work. You can use the 90-93 Integra axles and intermediate shaft combo, 94-01 Integra axles and intermediate shaft combo, or 99-00 Civic Si axles and intermediate shaft combo. You can mix and match with the 94-01 Integra and 99-00 Civic Si, but the 90-93 Integra parts must all be from those years. If you use the 94-01 Integra or 99-00 Civic Si axles but are using a cable tranny, then you will want to change the driver's side tranny seal to a 94-01 Integra seal.
thx, the hollander says i can use the del sol axles too.. didn't they have a D series motor?
oh well hehe, thx for the seal advice too.. i guess i have a 91 B18 with a 94+ tranny.. oh well mounts are the same so it's all good.. just that darn jack shaft...
one more question: could i use the 2g axle on the passenger side and the 3g on the jackshaft/driver side?
ITR632
04-21-2003 12:09 PM
JJ-Built
01-02-2002 08:27 AM
