fitting a gsr girdle on an ls block HOW?
I have a nicely equiped ls VTEC that has lots of up grades but I still have my old C1 and I was wondering how i could fit the girdle from it onto my LS engine. Is it possible and how or should I just buy a ls girdle aftermarket of course. Also how to fit a b16 intake manifold on a b18 head.
Re: fitting a gsr girdle on an ls block HOW? (matata55)
Guest
Posts: n/a
take the gridle, oil pan and oil pickup off the c1 mill caps drill for dowels put them on the ls block, incidentally i once found a b18b in the junk yard with the girdle windage tray and pick up from a c1, needless to say i snatched them up cheap.
Re: fitting a gsr girdle on an ls block HOW? (thad)
that was one of the best write up i have seen on ht but i called endyn how make blockgirdles exact replica of z-10 don't need to be doweled and are designed for lsvtec and bolt up if u get them doweled then u need to get the block line honed
Re: fitting a gsr girdle on an ls block HOW? (99lsvtecauto)
of course they are gonna tell you its "direct bolt on" cuz thats what everyone wants to here. if you want it done right, its gnna take time, effort, and money. gl tho, im gonna do the same thing. gsr girld and mill the caps
