Fuel Pump Question
I have a 97 Dx hatch with a B16a2 swap. I just bought a Zex kit & Purge. Will my Stock DX pump hold up to the 75 shot I plan on using or should I upgrade to a Walbro 190 pump? I also have a set of OBD2 GSR Injectors. Should I use these injectors instead of my B16 injectors.
The Si pump will be better than the stock DX one, however a Walbro would be better, at least you would need to worry about not having enough fuel pressure. As for the injectors, all B-series are the same.
If you are going to run a 55 shot then the Si pump would be sufficient enough. If you already have the pump then drop it in, if not I would go with a Walbro as the other's have suggested.
hondaeg8
Nov 16, 2004 01:07 AM
-Darren-
13
Mar 15, 2002 11:44 AM
