usdm b18c5 swap into 92-95 eg
Im not too familiar with these swaps so id like to ask a couple questions:
How hard is it to get bar certification since i live in california?
How hard is the swap to do?
What motor mounts work the best?
What kind of quartermile times can i expect from b18c5 in a hatch?
Does the car need to be run on usdm itr 5 lug or can you use gsr 4 lug?
ive searched but these are more direct questions i cant seem to find
Re: usdm b18c5 swap into 92-95 eg (JadeDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadeDM »</TD></TR><TR><TD CLASS="quote">Im not too familiar with these swaps so id like to ask a couple questions:
ive searched but these are more direct questions i cant seem to find</TD></TR></TABLE>
1.getting a certification is kinda a headache but do-able
2.the swap is something you can do by yourself ...but if it is your first time....you will definitely **** "something" up
3.Stock 94-00 integra mounts will work fine
4. 14.5 on street tires at least
5.you do not need a 5 lug suspenion to run the motor
if your in the bay area, i am too.....pm me if you need some help
Re: usdm b18c5 swap into 92-95 eg (SUPERNATURAL)
I am new to this too and wanted to know if I need to get an obd1 distributor if I am putting a 01 ITR motor into a 94 civic? Any help you guys could giv me would be awesome...thanks
Re: usdm b18c5 swap into 92-95 eg (94RedEGCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94RedEGCoupe »</TD></TR><TR><TD CLASS="quote">I am new to this too and wanted to know if I need to get an obd1 distributor if I am putting a 01 ITR motor into a 94 civic? Any help you guys could giv me would be awesome...thanks</TD></TR></TABLE>
you can use the 0bd 2 distributer and harness but you need to run a wire from your distirbuter directly to the tach.....the wire is VERY simple.....keep in mind the alternator, injectors must all be obd2.....
thanks for the info, but I decided to go with an obd1 jdm b18c1 with a civic si tranny, should be really simple and pretty quick.
1337 Si
05-23-2004 03:52 PM
vvti_01
03-12-2004 01:17 PM
JDM CTR EK
04-11-2003 04:32 PM
