Whats better, Cable or Hydraulic tranny?
I really dont know the difference. Id imagine a cable tranny has cables that control gear selection but I have no idea how a hyraulic tranny works. Also for a car that will be road raced and Never daily driven which is a better choice?
My car is a shell and have nothing right now. Since cable is cheaper should I just go with that since Im starting from scratch??
Modified by Demon_Dub at 12:15 AM 9/16/2004
Re: Whats better, Cable or Hydraulic tranny? (Demon_Dub)
Its reffering to the clutch mechanism, not the linkage bars or cables that shift the transmission.
Re: Whats better, Cable or Hydraulic tranny? (delLudeVTEC)
Ahh, so a cable tranny uses a cable that engages/disengages the clutch while a hydraulic clutch uses hudraulic pressure? Is that correct? I have a 92 hatch with no drivetrain, which is the better or easier setup to swap in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demon_Dub »</TD></TR><TR><TD CLASS="quote">Ahh, so a cable tranny uses a cable that engages/disengages the clutch while a hydraulic clutch uses hudraulic pressure?</TD></TR></TABLE>
That is exactly correct.
Stick with a hydraulic tranny(what your car came with).
no it will be easier to go with the hydraulic since the firewall is setup to mount the clutch master cylinder. o ne thing to rememebr is that no matter how stiff the clutch is a hydraulic setup never stretches like a cableone does.
if you wnt to go with a cable tranny get the pedal assembly from a 91 or earlier civic and hook that up, it may take some small mods to fit though.
Re: (91IntegGS)
cable trannys are cheap, especially ls cable trannys. A hydro to cable conversion is $199, very easy installation. You can find ls cable trannys for 300-350 all day long.
Re: (dohcdelsol93)
FYI, cable trannies (except the cable GSR tranny) all have smaller input shafts, whereas the hydro has a larger one. That alone makes the hydro's stronger.
Re: (hypa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa »</TD></TR><TR><TD CLASS="quote">FYI, cable trannies (except the cable GSR tranny) all have smaller input shafts, whereas the hydro has a larger one. That alone makes the hydro's stronger.</TD></TR></TABLE>
This is partially incorrect. There are two "generations", if you will, of b series cable tranny. The ones made in 89-91 and the ones made in 92-93. The 89-91 versions have the smaller shaft. The 92-93's (not just the gsr) have the same size input shaft as the hydro trannies.
Re: (91IntegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegGS »</TD></TR><TR><TD CLASS="quote">The 92-93's (not just the gsr) have the same size input shaft as the hydro trannies.</TD></TR></TABLE>
thanks for the clarification.
I found this out by accident, when a customers clutch disc no longer fit the tranny.
Re: (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 »</TD></TR><TR><TD CLASS="quote">cable trannys are cheap, especially ls cable trannys. A hydro to cable conversion is $199, very easy installation. You can find ls cable trannys for 300-350 all day long. </TD></TR></TABLE>
for an N/A car and LS tranny is not quite the best best setup. spend the 500-600 for a GSR/B16 tranny and be much happier. Not to mention why would you want a 14 year old tranny, sometimes ppl's cheapness gets the best of them.
SnowSurfer
10
06-15-2005 01:57 PM
ldanphanl
03-06-2005 08:50 PM
