Which driver's side mount do I need for an h22 swap into an Accord/CL?
I called the dealership here and they told me there were two mounts on the driver's side. I don't remember what he said exactly, but he said one mount was a "rear somethin-somethin" and the other mount was the "engine side mount." I'm leaning towards the "engine side mount," but I want to make sure. Can someone confirm this for me on hondaautomotiveparts.com or slhondaparts.com by showing me which exact part? Thanks.
Re: Which driver's side mount do I need for an h22 swap into an Accord/CL? (OutlawCL)
For engine mounts - you can use accord ones for front/rear/passenger side - but you need a prelude driverside mount engine mount and will require a little grinding to fit it properly.
This is what I had to do for my H22 swap into my '94 Accord.
ummm, my friend did the h22 into cl swap back in 99'.....he used a prelude mount that came with the engine and he "didnt" need to modify it...hope that helps
