HELP WITH K20 IN CRX AND EG
-DO THEY MAKE MOUNTS FOR THIS SWAP YET?
-WHAT SHAFTS DO I USE?
-WHAT ECU TO HARNESS DO I USE?
-PLEASE TELL ME IF I NEED TO NO ANYTHING ELSE IMPORTANT..
THANKS GUYS
THANKS GUYS
Re: HELP WITH K20 IN CRX AND EG (fastest)
There are aftermarket mounts for the EG swap but none for the crx swap.You should use a Hondata K pro modified ecu.Which model depends on which K series youre going with and which tranny.Use the factory K series engine to ecu harness w/ a Hasport or Hybrid modified harness.For the EG swap you need hasport axles,for the crx you use ep3 civic si inners and shafts and LS outers.
extras:
Hasport,DTR or TSX header
Accord or RSX shift box and rsx cables
Much more but its late and im tired.Will post tomorrow
extras:
HT White Ops
Re: HELP WITH K20 IN CRX AND EG (JDMotive)
Brian from Hasport says the EF mounts that will be used in your CRX will be out by SEMA. They will require a custom hood due to how tall the K series is.
TitoSweetJr
10
08-11-2011 02:27 PM
