what axles for my swap?
93 civic coupe with SiRII b16. i have been driving on the axles that came with the motor but they are in pretty bad shape.i have heard get 90-93 integra axles and get del sol si vtec axles. what would work best with my setup. im going to get them from pep boys or whoever it is that has the lifetime warranty ( i broke a lot with my last car ).
Thanks for the help
Thanks for the help
Re: what axles for my swap? (Love2race)
i have a question related to this topic. I put gsr cv's and intermediate shaft into my 94 ex coupe when I did my swap. THe cv's and intermediate shaft are for an abs model but my car is non-abs does it matter which cv's I use cause I've had really bad vibration ever since I did my swap. happens around 5500 rpm around 50 mph under full throttle only
Re: what axles for my swap? (dwnthehatch)
i was told abs axles in non abs car had no effect. its only a problem in the opposite situation.
i realize that there are several different axles that would work but they are all different so I want to know which set would work the best. car is fairly low also.
come on guys i know u have plenty expirience with this. i want to make sure i get the correct axles.
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">94-00 integra and 99-00 civic si axles will work.</TD></TR></TABLE>
If your car has no ABS and there is an abs ring on the axles than you can just pop that ring off.
1337 Si
09-09-2011 04:28 PM
