Axle dilemma with EK w/B16
Hey guys,
For some reason, my passenger side axle keeps pulling out at the hub side of the axle. The B16A2 is in a '98 coupe.
I'm using '94 LS axles at the time, figuring all B-series were the same. Maybe I'm wrong, but my new theory is that the DC and EK chasis' are different in more ways than I thought. Everywhere I check, the 99-00 Civic Si axles have a different part number than the 94-01 LS axles...
Would the Si axle work for my application? I'm quite tired of these bearings pulling out on me. It's happened 3 times now.
Location: We Cant Stop Here This Is Bat Country, So CaL, USDM
Re: Axle dilemma with EK w/B16 (drobinson)
The B16 (SI) axles will work perfectly lengthwise remember the EK has a B16 option. I am pretty sure the spline count is the same as the DX hubs you have so they should slide right in. Double check on the spline count though.
Maybe I don't understand your dilema correctly, but how does the axle pop out of the hub with the axle nut torqued properly and the nut staked? I have used integra B-series axles with no problems. I believe all B-series axles (94+ integras, Vtec del sols, 99-00 Civic Si) are compatible.
Jbur074
23
10-12-2007 07:41 PM
stockegsix
10-15-2002 09:34 AM
