JDM Type R swap driveshafts
JDM Type R swap driveshaft problem
ok well im about to do a jdm type r swap, that is going into my 92 civic vx. i know the motor is comming with jdm type r driveshafts, and i know the jdm ones use 36mm splines and the usdm ones use 32mm.
so my question is what driveshafts do i have to use, or is there anyway i can modify these ones so that they will fit in my car.
thanks for any help
and yes i did search
Modified by JayDM_TypeR_EG at 7:18 PM 9/13/2004
thanks for any help
Re: JDM Type R swap driveshaft problem (JayDM_TypeR_EG)
I believe 96-97 jdm R has 32mm and 98+ switch over to 36mm......correct me if Im wrong someone. I just finish swaping my 96 jdm R into ek and the axles bolt up perfectly....
Re: JDM Type R swap driveshaft problem (Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moua »</TD></TR><TR><TD CLASS="quote">I believe 96-97 jdm R has 32mm and 98+ switch over to 36mm......correct me if Im wrong someone. I just finish swaping my 96 jdm R into ek and the axles bolt up perfectly....</TD></TR></TABLE>
i think that most 96-99 ITR's had the 32mm axles nut. The 00-01 had the larger 36mm axle nut. just from buying the newer 5 lug with 16" gunmetals that i know that.
Re: JDM Type R swap driveshaft problem (Cnote)
ok i found out i need to change the outer ends on the axle, can i use the outers from my civic drive shaft or do i need the ones from and integra?
anyone know if this will work
Modified by JayDM_TypeR_EG at 4:07 PM 9/14/2004
GT3
04-24-2006 08:54 PM
